Displays detailed information about redundant ports.
N/A.
None.
The following command displays information on software-controlled redundant ports on the switch:
show ports redundant
Following is sample output from this command:
Primary: *1:1 Redundant: 3:1, Link on/off option: OFF Flags: (*)Active, (!) Disabled, (g) Load Share Group
This command was first available in ExtremeXOS 11.1.
